Some insight on Edge Port issue with dielectric medium
Altair Forum User
So I'm getting an error that says that I am not allowed to create an edge port on a dielectric medium, but it is clearly on a PEC.
Does anyone have an idea on what I am missing?
Also if this is the wrong place to ask this sort of thing feel free to delete it.
TIA.
Hi @Zain
Sorry, the error message is not clearly stating what the problem is:
MoM/MLFMM does not support port definitions that defined on PEC/metal strips that lie on a dielectric SEP region.
You have a couple of choices:
- set the solution for the dielectric region to VEP
- remove a small section of dielectric in the vicinity of the ports
- define the ports such that they are embedded inside the dielectric - you can imprint a new edge on the metal rods and define the edge port at that location
- use FDTD as the solver
0 -
Have a look at the following post:
0 -
Thanks JIF, the post you suggested helped.
