How can I extract the magnitude of a single harmonic in a spectrum and assign it to an I/O parameter using a pyflux commend?
C_Favre
C_Favre
Altair Employee
edited April 2024 in Altair HyperWorks
The magnitude in a spectrum 'Name' of harmonic number 'HarmonicNumber' is obtained by the pyflux command:
CurveVariation2D['Name'].spectrumResults[HarmonicNumber].amplitude
Both the magnitude extraction and the I/O parameter update can be done in the same pyflux command line. Here the I/O parameter 'ParameterName' is assigned the magnitude of harmonic 'HarmonicNumber' from the spectrum 'CurveName':
VariationParameter['ParameterName'].formula=str(CurveVariation2D['CurveName'].spectrumResults[HarmonicNumber].amplitude)
Note:
the I/O parameter should be defined as a formula type. It must be created in Flux before running the pyflux command.
Example:
1. Extracting the magnitude of a harmonic:
Extracts magnitude of harmonic #2 in curve SPECTRUM. The value is given in the Output Window when executed in an interactive session.
2. Extracting the magnitude of a harmonic and assigning it to an I/O parameter:
The command extracts the amplitude of the second harmonic from the SPECTRUM curve and assigns the value to the parameter HARMONICMAGNITUDE.
Welcome!
Welcome!
