Optimization workflow using Altair SimLab and HyperStudy for E-motor model
Lavanya Vadamodala_20519
Altair Employee
edited October 2024 in Altair HyperWorks
In this video, we present a detailed guide on setting up and running Design of Experiments (DOE) and optimizing a parameterized E-model in Altair SimLab. Follow along as we demonstrate the step-by-step procedure to configure your DOE, execute simulations, and fine-tune your model for optimal performance. Ideal for engineers and designers aiming to enhance their simulation capabilities and achieve precise, reliable results. Watch now to master DOE and parameter optimization with Altair SimLab!
Check out the video on parameterization in SimLab for the E-motor model at https://youtu.be/aRuos1nAQLU
