How to Remove Joints from Rigid Diaphragm Constraint in Altair® S-FRAME™
Matthew_Sauer1
Matthew_Sauer1
Altair Employee
edited March 2024 in Altair HyperWorks
In this video we will investigate the situation where two adjacent rigid diaphragm panels may constrain the same joint and cause an FYI CO108 Solver Diagnostic Message during analysis. We will look at how we can prevent this by removing the shared joints from one or more of the rigid diaphragm constraints.
https://youtu.be/LTMTchaEiXw?si=8AxoBi5t_UehDYYI
