Upgrading to Altair License Manager Version 15.5.0 on Windows
Sasi_Mrudula_Gudem1
Sasi_Mrudula_Gudem1
Altair Employee
edited July 16 in Altair HyperWorks
Download the Altair License Manager from Marketplace on Altair One. The License Manager Tab would be accessible for all the applications for which you have a license.
Save the executable in a local drive on the Server on which it is to be installed.
Before installing ALM15.5.0, the current version of the Altair License Server should first be uninstalled, and all the directories are to be deleted.
It is suggested to have a backup of the altair-serv.cfg, alus.conf files, data, and logs folder from the licensing folder, before uninstalling the current version of ALM. A backup will usually be taken by default when uninstalling the older ALM.
Once done, refer to the video showing the steps to install the latest Altair License Manager.
Please Note: Please make sure there is only one *.dat  or *.lic (license file) in the installation directory.
