🎉Community Raffle - Win $25
Join and Win
New and Improved capabilities common to all clients in the new HyperWorks 2022 user interface
User: "Chayan"
Altair Employee
Updated by Chayan
Lets take a look at some of the important new and improved capabilities common to all clients in the new HyperWorks user interface
View Cube
Use the view cube for easy model orientation.
https://www.youtube.com/watch?v=H1bowIQrT1Y
Toolbelt
Use to toolbelt to quickly access frequently used tools in HyperWorks.
https://www.youtube.com/watch?v=wWs_Kw8aYE0
Extensions
The Extensions infrastructure provides the main entry point for custom content.
https://www.youtube.com/watch?v=Ng2fK9coIco
Command Recording
HyperWorks Command (HWC) language coverage, which allows you to record and playback workflows in HyperGraph, has been expanded to support the following features. Tasks performed using these features are recorded in the HWC syntax and can be logged in HWC or Tcl syntax on the file system. The command line supports auto-completion and interactive help, and allows easy modification and re-execution of commands.
https://www.youtube.com/watch?v=uMeBNfEeIAk
Dark Theme
Use the dark theme to reduce your eye stress.
https://www.youtube.com/watch?v=kVRYKyIMqso
HyperWorks Report
https://www.youtube.com/watch?v=SES1gjAqdiM
One Click Report
For Model Summary and Session Report
https://www.youtube.com/watch?v=4eMxP15W8SA
Automatic Report Generation
Create flexible reports of your sessions using custom or default templates.
https://www.youtube.com/watch?v=Kd8NmyAsKsw
Pulse
Altair Pulse is a low-code environment to construct and orchestrate engineering workflows involving many software tools from different sources.
https://www.youtube.com/watch?v=fvNzhoXajj4
Return to the User Migration Blog
No comments on this post.
