🎉Community Raffle - Win $25
Join and Win
FEKO 2024 CADFEKO (UI) cannot write to a network share. Is it normal?
User: "Andrew_21618"
Altair Community Member
Updated by Andrew_21618
While IntelMPI in the current version does not work well in Windows, I am trying to study using laptop, but tried working from the common share on a remote workstation.
So I can load a project from the share. But when trying to save, or run a simulation, it throws an error telling that the share in not writable.
Of course, the sahre is writable. The access is organized with local credentials(user/password stored at the host)
I suspect, some incorrect identification accurs in the writing routine. It probably writes under different user, than the one logged in to the share from laptop, and stored in laptop's credentials vault for that share. Of course it may be anything else.
I.e. is there a fix or workaround?
