EDEM - Hyperstudy connection
Hi, I am trying to use hyperstudy to vary some parameters of my edem simulations, I followed the mixer tutorial, all the files get generated and parameters get adjusted but the simulations do not execute (the responses output is also empty), what might I be doing wrong?
When hitting 'Run definition' in the setup, it is also done almost instantly
