Antenna feed gap capacitance
When using a voltage source to excite an antenna, will the FEKO-computed input impedance include the capacitance of the assumed gap between the feed terminals of the antenna? If so, what does the capacitance represent? Is it the capacitance of a hollow cylinder, or the capacitance of a solid cylinder, or something different? Feed gaps are tricky...
