Error in C code integration
Submitted by Mala Gowda on Tue, 12/18/2012 - 11:29
Hello:
i complied Example_2803xLEDBlink in CCSV4.it is working fine on TMS320F28035 Control card. when i use extern fuction block to integrate same c code in visSim, i see error as attached in command prompt. what could be the reason. i have even set user objs too. please let me have solution for this.
Regards, MALA
