Refinement Box Does Not Refine Surface Elements
I want to refine the mesh in certain portion of a solid mesh and have used refinement box option. But it refines only the interior elements and keep the surface elements same. How to refine the surface using refinement box? Below are the settings used and the results I got.
Thank you.
