3d meshing a very thin region of a rod
I want to 3d mesh a rod with curved profiles at both ends, but I am not able to mesh the ends of the rods properly leading to element errors which I am not able to solve. Also I want to 2d mesh a cylinder connected to the rod at one end and then link the 3d elements on rod and 2d elements on cylinder. I have attached the model file and also the images of the cross section of rod and cylinder.
Please help me with the same.
