loadstep
Hi everyone,
I am starting in HyperMesh and I have a doubt about the loadstep.
In case you have more than one boundary condition (2 constraints or 2 forces), when you have to select in LOAD ( for example),
the differents loads in the analisys I am not able to select all the loads. I can only select one load and I do not know the way to select all the different loads.
I hope you have understood the question and you can help me.
Thank you /emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
