🎉Community Raffle - Win $25
Join and Win
Inspire Selecting Entities That Overlap
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I have two related selection questions:
1) I would like to select the bottom face to pull of the plate in the attached picture ('select_other_side.jpg' top face is selected) without having to rotate the view to look from the underside. Is there a way to cycle through selections to pick the entity I want?
2) After creating a sketch ('sketch.jpg' attached) on an existing plate and using the plate curves to create a new part I would like to pull these curves to extrude but when I go to select to pull the original plate face is selected and not the new face created, is there a way to cycle through selections to pick the entity I want?
Regards,
Clayton
