Remote Desktop Connection Issue
Has anyone else tried to run HyperMesh from a computer they are remote desktop connected to. There seems to be an issue, at least with V11.0, where the working window shrinks to about a 1/4 the size of normal. It only happens for HyperMesh. If I switch to HyperView, for example, the working window changes back to normal. Then when I switch back to HyperMesh it goes back to 1/4 size.
Is there a fix to this or am I stuck with a 1/4 sized window?
Thanks
