CADFEKO: is there a way to edit "transform" parameters?
I can edit the primitive parameters by double click in the hierarchy tree.
But when I apply a transform, it is reflected only as an icon. No matter, do I double click, or apply the same transform operation, the initial transform is not accessible.
In HFSS any transform is reflected as a separate accessible object in the hierarchy(history of operations) tree. Is there a way to access it in CADFEKO the same?
For example, I have an element of antenna turned by 45 deg. I want a copy of that element at different coordinates, but turned -45 deg around the new axis. I do not see how to do it here.
