in order to plot these results in HyperGraph export your data in a csv format. Then you will be able to open the file and select X and Y components with no issue. Hope this helps!
Hi,
of course you can do it.
I'm using normally Unicode *.txt file format ('save as' in Excel). Be sure that only the necessary datas are on the data sheet. (rows and columns)
In Hyperview -> Hypergraph 2D you can choose this file and select your requests for x and y (use preview, it's a nice feature)
Best regards,
Mario
PS: we have board section for hyperview ;-)
