TLC run
Hi to everybody,
i'm trying to create a model writing in the command window. I 'm following the tutorial showed in the pdf 'Motionview Tutorial' but i can't run the .tcl file. I try to explain better: after writing the model, it is required to save the script as .tcl format, in order to be able to 'call' the model and then to register it in the Preference file.When i try to call it i have this message:
This script should be run from the 'widget' demo.
I'm able to open .tcl format thanks to ActiveTcl or Vim 8.0, but i can't understand why MotionSolve can't run the model.
Can someone help me please?
thanks
