Bistatic RCS of RIS
Hi all
I built a RIS with 0 ° incidence and 45 ° exit. I need to get his bistatic RCS file. However, when I did the calculations in FEKO, the results I got were different from the theoretical results. As can be seen from Figure 1, there is a strong RCS at 0°, which is far from the theory. Is there anything I need to set up specifically for the bistatic RCS that calculates RIS in FEKO?
