How to get information of particles from the grid bin in edempy?
I use edempy for post processing. Until now, I used cylinder bin(Geometry bin) and get the position and Id of particle inside the bin.by this code:
Bin = CylinderBin([0,0.1, 0], [0, 0.2, 0], 0.01)
pIds = my_simulation_deck.timestep[t].particle[0].getIds()
pPos = my_simulation_deck.timestep[t].particle[0].getPositions()
ids_inside = Bin.getBinnedObjects(pIds,pPos)
But due to the huge number of particles, the process is too time-consuming. (I calculate the distance between all the particles) I think if I can define grid bins and do the calculation inside each grid It will be more logical in CPU time.( I mean it is more logical to calculate the distance between particles and only their neighbors)
I want to ask you, just like an above code, is there any way to get information in each grid?
Regards,
Fatemeh
