Tetramesh problem in hypermesh 2017
Hi guys,
I find there is some bug in tatramesh with hm 2017 while it is ok in hm14.0.
For the same solid, after I split it with same params, and then mesh the solid body, the number of node and elements are different each time in hypermesh 2017.2;
But in hm 14, It OK
The steps I do as follow:
1\open hypermesh
2\import utg model (attachment)
3\split the solid with X-plane-(0 0 0)
4\mesh the solids
5\remember the number of the node and elements
6\repeat 1-5 and compare with the first number.
How to fix this problem ?
Thanks .
