🎉Community Raffle - Win $25
Join and Win
FEKO failing to launch on WSL Ubunto
User: "pde_James_Britton"
Altair Community Member
./feko_launcher fails
I have installed feko on Ubunto in WSL. The installation output said it was successful. I have attempted to launch feko by calling ./feko_launcher from directory …/altair/feko/bin
I get the following message:
./feko_launcher
SetEnvVar[WARNING]: Expansion of value string for PATH did not succeed (ret = 2):
SetEnvVar[ERROR]: WRDE_BADCHAR: Illegal occurrence of unescaped newline or one of |
SetEnvVar[WARNING]: Ignoring error and using unexpanded value string for PATH unchanged as is!
qt.qpa.xcb: could not connect to display
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: linuxfb
Aborted
I have attempted to install the plugins and anything else that was suggested on the web. I do not have the background to fix any path issues.
