<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="7.1.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.1.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.1.001" expanded="true" height="68" name="Retrieve Golf" width="90" x="112" y="34">
<parameter key="repository_entry" value="//Samples/data/Golf"/>
</operator>
<operator activated="true" class="optimize_parameters_grid" compatibility="7.1.001" expanded="true" height="103" name="Optimize Parameters (Grid)" width="90" x="313" y="34">
<list key="parameters">
<parameter key="k-NN.k" value="[1.0;100;99;linear]"/>
</list>
<parameter key="error_handling" value="ignore error"/>
<operator activated="true" class="x_validation" compatibility="7.1.001" expanded="true" height="124" name="X-Validation" width="90" x="313" y="34">
<parameter key="sampling_type" value="stratified sampling"/>
<parameter key="use_local_random_seed" value="true"/>
<operator activated="true" class="k_nn" compatibility="7.1.001" expanded="true" height="82" name="k-NN" width="90" x="253" y="34">
<parameter key="k" value="100"/>
</operator>
<connect from_port="training" to_op="k-NN" to_port="training set"/>
<connect from_op="k-NN" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
<portSpacing port="sink_through 1" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34">
</operator>
<operator activated="true" class="performance_binominal_classification" compatibility="7.1.001" expanded="true" height="82" name="Performance" width="90" x="179" y="34"/>
<operator activated="true" class="performance_costs" compatibility="7.1.001" expanded="true" height="82" name="Performance (2)" width="90" x="313" y="85">
<parameter key="cost_matrix" value="[0.0 25.0;1.0 0.0]"/>
<enumeration key="class_order_definition">
<parameter key="class_name" value="yes"/>
<parameter key="class_name" value="no"/>
</enumeration>
</operator>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="example set" to_op="Performance (2)" to_port="example set"/>
<connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/>
<portSpacing port="source_model" spacing="0"/>
<portSpacing port="source_test set" spacing="0"/>
<portSpacing port="source_through 1" spacing="0"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="log" compatibility="7.1.001" expanded="true" height="82" name="Log" width="90" x="447" y="85">
<list key="log">
<parameter key="k" value="operator.k-NN.parameter.k"/>
<parameter key="performance" value="operator.X-Validation.value.performance"/>
</list>
</operator>
<connect from_port="input 1" to_op="X-Validation" to_port="training"/>
<connect from_op="X-Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/>
<connect from_op="Log" from_port="through 1" to_port="performance"/>
<portSpacing port="source_input 2" spacing="0"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
</operator>
<connect from_op="Retrieve Golf" from_port="output" to_op="Optimize Parameters (Grid)" to_port="input 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_port="result 2"/>
<portSpacing port="sink_result 3" spacing="0"/>
</process>
</operator>
</process>
All comments
Photo of YYH YYH
Could you post your process here for us to investigate that? Thx
Photo of Steffen_w Steffen_w
I created a test-process on the golf-dataset with the same situation. In the log, the optimum costs are at 0.350, the optimizer shows 10.2
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="retrieve" compatibility="7.1.001" expanded="true" height="68" name="Retrieve Golf" width="90" x="246" y="34">
</operator>
<operator activated="true" class="optimize_parameters_grid" compatibility="7.1.001" expanded="true" height="103" name="Optimize Parameters (Grid)" width="90" x="581" y="34">
</list>
</operator>
</process>
</operator>
<enumeration key="class_order_definition"/>
</operator>
</process>
</operator>
<list key="log">
</list>
</operator>
</process>
</operator>
</process>
</operator>
</process>
Photo of MartinLiebig MartinLiebig
Dear  Steffen,
you need to set the class ordering. The behaviour without that is odd. I would have expected an error and not that it does something wrong. If you set the class ordering in Performance (Costs) it works. See attached process.
Another comment: The minimum found by log and by optimize are different. The reason is because one is logging the macro the other the micro performance (weighted and unweighted average of the k-folds). On a bigger data set, this should not make a difference.
~Martin
Spoiler
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
</list>
</operator>
</process>
</operator>
</enumeration>
</operator>
</process>
</operator>
<list key="log">
</list>
</operator>
</process>
</operator>
</process>
</operator>
</process>
Dear Martin,
thank you for your help! Now it's working!
-Steffen
