🎉Community Raffle - Win $25
Join and Win
Centrifugal force
User: "raju mandal"
Altair Community Member
Updated by raju mandal
hi, i have a rotor assembly. I want to know if there is any method in hypermesh to apply centrifugal force??
Description of model:-
It consist of a shaft which can rotate in a bearing. Shaft has two discs at ends attached. The discs has hole via which a rod is connected. Now that rod has some smaller discs(hammers) again. These hammers can rotate about the rod.
Can anyone help me to find the centrifugal force in the hammers when I am given rpm of shaft, power of motor..
thanks in advance
