Segmentation Error in Hyperworks 2019
Hi everyone,
I was wondering if anyone could help me identify what's causing the segmentation error?
I wrote a TCL Script as a test, the idea is to import a .dxf geometry, create solids then mesh them, then delete the model and import another .dxf to do the same thing.
However, Hyperworks always crashed during the meshing process of the 2nd geometry (I checked the crash0.hm file).
This seems to work when I did these manually, but running the script from command.tcl also produced a segmentation error at that exact spot.
Running it on a different computer didn't work either.
Thanks a lot in advance, would appreciate your help!
