hello,
I am not able to find maximum shear stress please help me to find in hyperview. it is only showing displacement and von mises stress
tkank you...
Hi
Please, goto control cards > Global output request > Select Stress output > for Type select All as shown below. Then, run the analysis.
Thank you
Hi Please, goto control cards > Global output request > Select Stress output > for Type select All as shown below. Then, run the analysis. <?xml version="1.0" encoding="UTF-8"?> Thank you
Hey Premanand,
I'm also trying to find shear stress but cannot find the Global output request panel. If I click on Analysis > Control Cards, I have several pages full of options, but nothing called Global output request. I'm working in Hypermesh - can you help me?
Please go to next page. You will find global output request menu.
Please go to next page. You will find global output request menu. <?xml version="1.0" encoding="UTF-8"?> Thank you
Thank you for your answer, but no - as mentioned above, I have several pages full of options and I clicked through all of them but did not find global output request. The first page also looks different at my end..
http://oi65.tinypic.com/2j67b6g.jpg
Please can you tell me which user profile you are using?. Make sure you are using OptiStrcut profile.
Please can you tell me which user profile you are using?. Make sure you are using OptiStrcut profile. Thank you
I use Radioss. Isn't it possible in Radioss?
Go to > Analysis > Control cards > ENG_ANIM_ELEM
And check all the shear stress options as shown below.
rea2
Is your issue resolved?
