Reflector Antenna with plane wave as a feed
Altair Forum User
Altair Forum User
Hallo,
I'm trying to design a dual reflector antenna and I'm using as a test a plane wave as a feed system with CADFEKO. But when I try to create mesh the software blocked and in 7% and I should close the whole software. I have a student version of Feko and I'm a new user of it. So maybe there is something missing in my design. In GRASP a plane wave can be used as a feed system and its size and coordinates can be set as well but in Feko I didn't find such a thing yet.
I would appreciate your help so much.
Thank you for your attention :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
  • Altair Forum User
    Altair Forum User
    edited July 2017
    Hello Corny,
    Yes, you can model a plane wave excitation in FEKO. You will find it on the Source/Load tab under the ideal source section. If you would like us to check what is happening with your model you can attach it here.
  • Altair Forum User
    Altair Forum User
    edited July 2017
    Hallo Peter,
    Thank you very much for your reply. I attached my model here. For the wave plane I didn't know how to change its dimension and z- coordinates.
    I will appreciate your help so much.
    Thank you :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
