Elements in proximity of nodes
Hi @NFMOREIRA
If the nodes are associated with the elements, there is option to find attached using TOOLS > FIND option in HyperMesh
However there is no direct option to find based on Tolerance. For this you may need to do customized scripting or automation.
0 -
Hi Pranav
Exactly. I use that command for attached elements.
For this case however, I would need to do a script. The problem is that I do not know at the moment, how to transform the idea into the script.0 -
Hi NFMOREIRA
You can learn the basics of scripting from the online tutorials available in HM help.
Hope these links may help you.
0 -
Thanks Pranav /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
0 -
Altair Forum User said:
When a list of nodes is imported to a meshed model, is there a way to find what elements are near each imported node, given a certain tolerance?
If so, how to select and export these elements?
Thanks for your help.
N.
Hi @NFMOREIRA
::hwat::utils::GetClosestElement x y z assemname
May be this is the command you are looking for, x y z are the coordinates of corresponding node.
