Overlapping of Hexa elements in ACM welds
Altair Forum User
I am welding two plates of 5mm thick using ACM welds. I am using the 'spot panel' in the 1D connector tab. Following are the inputs:
spacing : 1.00
num layers : total 2
tolerance : 20
type : acm (shell gap)
diameter : 2
Though the connectors are realized, I find the overlapping of the HEXA elements. What could be the reason behind this and the solution to avoid the same?
Attached .bdf file
Thanx in advance /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Could you set the spacing to 2 or 3 and then create the connector.
