Mesh settings ignored in TCL script 2D surface meshing
User: "Weltraum"
Altair Community Member
Updated by Weltraum
I am facing a problem while creating a 2D surface mesh in TCL Code in hypermesh.
The settings done in '*interactiveremeshsurf' and 'set_meshfaceparams' seem to be ignored for all surfaces
and overwritten by the settings written the GUI at 2D-->Automesh-->Edge deviation.
The code can be seen below:
 	*setedgedensitylinkwithaspectratio -1 	*elementorder 2 	*startnotehistorystate {Automesh surfaces} 	 	*createmark surfaces 1 [lindex $List_OP($i) 0] 	for { set ii 1} {$ii <=[llength $List_OP($i)-1]} { incr ii} { 	*appendmark surfaces 1 [lindex $List_OP($i) $ii] 	}  	if { 1<=$i && $i<=3 } { 	# markmask, elementsize, elem_type (0 trias, 3 rtrias)  	*interactiveremeshsurf 1 0.25 3 3 2 1 0	 	set i_am 0 	foreach Element $List_OP($i) { 	# index (von 0), elem_type, alg_type, elem_size	 	*set_meshfaceparams $i_am 2 3 3 0 1 0.5 1 0 	*automesh $i_am 1 3 	incr i_am 	}          *storemeshtodatabase 1 	*ameshclearsurface  	*clearmark surfs 1; 	*endnotehistorystate {Automesh surfaces}
Am I missing some command?
Thanks and best regards,
Henrik
1 - 1 of 11
    User: "Weltraum"
    OP
    Updated by Weltraum
    Did someone encounter this problem already and perhabs has a solution?
    I would be very thankful for help on this issue. :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    Best regards,
    Henrik
