Coarsen tetra mesh
Yash_20384
Altair Community Member
Hello Everyone,
I have tetra mesh in my model. I want to coarsen the mesh size but there is no geometry in the model.
I tried using 3D > tetramesh > tetra remesh option but there is no change in meshing even after using this option. The geometry is complex therefore the Process of extracting faces and then remeshing / using new CAD geometry is time consuming. How can I coarsen the 3d mesh?
Thank you in advance!
Hey Yash,
Tetra remesh will coarsen the internal mesh.
If you'd like to coarsen it as a whole, use the Faces tool to generate exterior shell mesh:
Then remesh the exterior mesh with a larger elem size:
Then you can create a new Tetra Mesh with desired element size:
Kind Regards,
Paulo Libório.0
