Model problems
Altair Forum User
Your model has also shell/membrane elements, but I can not found their property. Or you forget to delete them?
Maybe that's not the cause of your error.
0 -
I forgot to delete them, thanks. But I have still the same error /emoticons/default_mellow.png' title=':mellow:' /> It looks like there something wrong with the boundary conditions.
0 -
A function is missing in your model file which is required for running.
It seems from the loads the function is missing. Do you have concentrated load or any imposed loads in your model?. If so, those loads require a function wrt time and the load will be ramped accordingly on to the model.
