Dyna_Output
Hello everyone,
I am building a python script to invoke HM to mesh the input file (.stp file in this case) and give .key file as output (for ls-dyna). I couldn't find Dynaoutput.tcl file and DynaOutputwithNewName.tcl in the installation folder. Could someone please share it here if possible?
Thank you very much
Altair Forum User said:
Hello everyone,
Thank you very much
That's strange! You're building 'python' script and you're looking for *.tcl files?
0 -
Thank you very much for your response. I am trying two methods. one is to use python where I combine CATIA and HM interface and second is to use them separately. I have attached the python file which I used. In that, under HM part, the default folders, were tcl file was mentioned. If not, in other case, I have also created a batch script file in .txt format. can I use hm.batch.exe under cmd line to execute the file?
I really appreciate your help and looking forward to hear from you.
0 -
hello again,
I tried to run the script (attached picture) from command line. I get the some errors. could someone please help me how to deal with it?
Thank you and looking forward to hear from you.
0 -
I see -run_results is a folder. should it be a file instead?
0 -
Thank you very much for your feedback. Actually I don't know what I did. Honestly I just tried adding and deleting different syntax such as run and now the script works. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />. I used like this -nogui - cad_translator -crit -param -userprocedure -work_dir. now it works perfectly fine.
Thank you.
0 -
If you don't know but it works => be careful /emoticons/default_wacko.png' title=':wacko:' />
