Difference between Bush and Spring
User: "CdricCd"
Altair Community Member
Updated by CdricCd
A basic question : what is the difference between Bushes and Springs in MotionView ?
Is a Bush an element composed of 6 Springs/Dampers ? Or is it more complicated than that ?
Thanks for the answer !
Cédric
1 - 2 of 21
    User: "Altair Forum User"
    Updated by Altair Forum User
    HI,
    Bushings are typically used to reduce vibration and noise, absorb shock, and accommodate misalignments.
    In MotonView,
    A Spring Damper entity defines a spring damper acting between two Bodies. The element can be Coil Spring translational (applies a force) or Torsion Spring rotational (applies a torque). In both cases, the force is characterized by a stiffness coefficient, a damping coefficient, a free length and a preload
    A Bushing entity defines a force and torque acting between two Bodies. The force and torque consist of three major effects: a spring force, a damping force, and a preloadvector.
    User: "CdricCd"
    OP
    Updated by CdricCd
    Ok thanks for the details ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
