Point To Curve
CdricCd
CdricCd Altair Community Member
Hello !
I have a little issue, might be very easy to fix for you guys ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
I want to create a point to curve joint, so I declare the two bodies, the point and the curve. But when I start the simulation I've got this issue : 'ERROR: Param curve of PTCV joint [id=301001] not found!'
Like it doesn't find the curve, but all seem to be well create (see pic) : the blue bar has to translate along the red line, simple as that !
The curve is defined as in the pic. I tried every combinations with the properties without effect...
Thanks for the help guys !
  • Altair Forum User
    Altair Forum User
    edited January 2018
    Can you please the .log file?
  • CdricCd
    edited November 2020
  • Altair Forum User
    Altair Forum User
    edited January 2018
    Can you check whether curve is referenced in PTCV?
    I see there are two PTCV joints (from log  Reading   2 PTCV joints...
    ERROR: Param curve of PTCV joint [id=301001] not found!)
  • CdricCd
    edited January 2018
    My curve (Joint1) is well referenced in the advanced joint, see pic below.
    That's why I don't know why it can't make any link between the PTCV and this curve... The model is made 2 PTCV and 2 curves (1 curve for each PTCV)
  • Altair Forum User
    Altair Forum User
    edited January 2018
    @CdricCd
    Yes but in log file it says one XY spline curve and 2 PTCV joints. Please check this.
  • CdricCd
    edited January 2018
    I have two curves which are created with the entity curve, and these two curves are linked to each PTCV... Maybe it's not the correct entity for this kind of Joint ? I tried with Spline but PTCV can't detect splines when I have to select the curve...
  • Altair Forum User
    Altair Forum User
    edited January 2018
    Can you share the model file please?
    Use the file transfer link in my signature to share the files.
  • CdricCd
    edited January 2018
    I'm not allowed to share my models but i created a very simple one with the same principle and the same issue...
    So I guess I don't use the joint properly...
  • Praful
    Praful
    edited January 2018
    Hi CdricCd - Could you open the XML file in a text editor and check if <Reference_ParamCurve statement corresponding to the Constraint_PTCV is available ? It is also possible that the curve has insufficient data. I think you might need atleast 4 or 5 data points for the curve to be written out.
    Regards
    Praful
  • Altair Forum User
    Altair Forum User
    edited January 2018
    HI @CdricCd
    Please see the warning message:
  • CdricCd
    edited January 2018
    Thanks guys the problem was the number of points on the curve, I put 5 of them and it's alright !
