I have edited the .adf file as I wanted to add a steering controller. After editing the necessary changes when I am running a straight-line braking simulation the .adf file is back to its original state and the edits are gone. Do I need to select the .adf file from within the software somewhere?
I need this controller as I want to conduct a straight-line braking event, but the scooter is leaving its plane for some reason, I have tried couple of ways to lock the steering, but they didn't work, and this method was suggested by someone on this community and seems to be a promising solution. Can anyone help me.
I have attached a text file containing all the .adf file values which is there by default in the simulation.
and these are the guide files I am referring to for creating a straight path.
Feed-forward Steering Controller - Two-wheelers (altair.com)
Sequence of Straights and Arcs (altair.com)
One more thing in the braking simulation how to select the straight path created in .adf? because i can just select a .rdf file from there
Regards
Draucis
