Analysis Result for Lattice Structure Optimization
User: "Aslan_20882"
Altair Community Member
Updated by Aslan_20882
Hı,
My question, what is the difference between the following options.
These results are calculated according to what?
Thank you.
1 - 9 of 91
    User: "Altair Forum User"
    Updated by Altair Forum User
    Hi Busra ASlan,
    These are the stress results of the component, which is shown for each element. It is calculated based on the Boundary conditions. Can you please elaborate your question or let us know what specifically you looking for.
    Thank you
    User: "Aslan_20882"
    OP
    @Premanand Suryavanshi
    Thank you for your reply.
    Actually, I want to learn these questions,
    1. Element Stress(2D-3D) means that the stress value all component of the model, is the truth?
    2. CBAR-CBEAM Stress means that the stress value of the only lattice structure is the truth?
    3. What is the difference between CBAR-CBEAM Stress (ROD) and CBAR-CBEAM Von-mises Stress?
    4. Displacement show that the value of all components of the model, is the truth?
    5. What does it mean Element Stress (1D)?
    Thank you.
    it is the stress value for all 2D and 3D elements in the model
    yes you are right
    yes.
    These are stresses of all 1D elements in the model
    CBAR-CBEAM Stress (ROD) is the normal stress,
    Whereas, CBAR-CBEAM Von-mises Stress i the average stress (It follows vonmises criterion).
    Thank you
    User: "Aslan_20882"
    OP
    Thank you @Premanand Suryavanshi
    I understand well :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "Yuan Liu"
    Updated by Yuan Liu
    How  to get the output of CBAR/CBEAM von Mises Stresse?
    User: "Simon Križnik"
    Updated by Simon Križnik
    the von Mises stress will be output by default when using PBARL or PBEAML with standard cross section.
    User: "Yuan Liu"
    Updated by Yuan Liu
    So what's the difference between pbeam and pbeaml?
    PBEAML allows selecting from a library of standard cross-section shapes such as BAR, BOX, BOX1, CHAN, CHAN1, CHAN2, CROSS, H, HAT, HEXA, I, I1, L, ROD, T, T1, T2, TUBE, or Z.
