Hex mesh
Hi Busra Aslan
Can u share with us more details about the model or a snippet of it.
0 -
Hi
OK we will check and revert
0 -
Altair Forum User said:
Another video. Simply model with solid edit and make it mappable
0 -
Thank you @Pranav Hari, @Prakash Pagadala
Actually, before I writing I worked steeringwhell_hexa.pdf but I didn't understand well.
Do you have any other video to guide me?
0 -
Hi @Aslan
There are a few videos available on youtube, you can refer to those. There is no thumb rule or straight procedure available for hexa meshing.
0 -
Thank you for helping @Prakash Pagadala
Actually, I watched the videos and other all videos
/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
But I don't fully understand, what should I think do for solid edit.
Thank you.
0 -
I hope the tutorial shared here on Hexa mesh will help you.
where did you take this manual?=)
i couldn't find this one in altair connect.
0 -
Hi @Mrt
You can get it from here https://altairuniversity.com/learning-library/hypermesh-12-0-hexa-meshing-a-steering-wheel/
0 -
@Pranav Hari thanks a lot.
i saw it folder in altair site=)
there are many books/videos/manuals
but difficult to search that you need=)
0 -
We are improving our system consistently along with adding new learning material on Learning Library.
0 -
thank you for everything @Prakash Pagadala
I don't understand what we want to do solid edit(Trim)
I'm trying but probably part is the most difficult in hypermesh
How will we decide to be a trim area?
And soryy
/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' /> Can you share your full file.
0 -
You can start by trimming solid with lines. Since it is easy to divide the solid into small chunks with lines, I prefer to start with trimming by lines and 99% is done with trim with lines.
The model I shared, is the complete model...
0 -
Thank you for everything @Prakash Pagadala
I am trying, I hope I can
/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
