Monarch Classic
Atiq Siddiqi
Altair Community Member
Hi Atiq,
Classic
- If you're opening an Excel file in classic I would make sure the excel file is closed.
- Next you want to open it as a 'Database'
- Click on 'Computer' to browse to the file
- Select the table, which means the tab in the workbook you want
- then 'Import' the data.
Data Prep Studio
- Click on 'Open Data'
- Browse to Spreadsheet
- Two Options;
- Excel Worksheet Design: Takes you to 'Excel Trapping'
- Microsoft Excel: Opens the Excel files as is
- This will open an Excel Explorer where you can select the tab(s) you want.
- You can 'Preview' the tabs, or simply load them to the 'Prepare' window where you will work with the data.
