Hi, I have few modal analysis and I need to compare modal frequency. Is it possible to change step (or substep) in few windows by one click? For example for the next modal shape, one click and I would like to have next Hz for all windows at once.
Hi Jakub,
Can you try with the Synchronize Windows option?. The Synchronize Windows feature allows you to manipulate the view matrix of multiple models in multiple windows at the same time.
Yes, That is working in rotate and zoom of object, but I cant change frequency on two window by one click, i need to pick active window, and than change step (or substep - frequency)
I figured it out!!
1. Change the substep for one of your windows (the active window is the one that was last left-clicked)
2. Right-click in that same window and select 'Apply Style' > 'Select Options'
3. In the new dialogue window that opens, select the 'Apply to:' and select 'All Pages'
4. Check/Uncheck all attributes you want to apply to all. Note the Icons at the bottom of the window that give check/uncheck options (above the 'default button')
Note the 'Results Steps' will change the substep to be consistent across all windows.
5. Click Apply!
Cheers guys!
