how to create the output request to measure the Toe angle?
RAMGANESH
RAMGANESH Altair Community Member
Dear Sir,
I working on the MBD simulation of the suspension system i need to know how to create the output request to measure the Toe angle?
Kindly provide your guidelines
Thanks
Ram
  • Altair Forum User
    Altair Forum User
    edited May 2015
    Ram,
    toe angle is angle made by the wheels when looking from the top view, which is AZ.
    So you have to create an output expression to output rotational displacement (AZ) of the wheel.
    Please refer to help for more information about the function AZ.
  • RAMGANESH
    edited May 2015
    Dear Sir,
    Is there is any tutorial for to create an output expression to output rotational displacement (AZ) of the wheel with more information about the function AZ.
    Thanks
    Ram
  • Altair Forum User
    Altair Forum User
    edited May 2015
    Ram,
    I did not find any tutorial to define Toe angle so far.
    Follow the below steps:
    1) Create Two markers. one attached to wheel and the other attached to ground body
    2) Go to Output panel and create a Function for AZ
    3) AZ ({IDstring of marker of wheel}, {IDstring of marker of ground})
  • RAMGANESH
    edited May 2015
    Dear Sir,
    I have created the markers and AZ function as per your instructions but the graph plot is like this
    I have created the markers with same axis and plane,is it correct or not?
    Thanks
    RAM
    <?xml version="1.0" encoding="UTF-8"?>post-34029-0-70053400-1432187041_thumb.p
  • Altair Forum User
    Altair Forum User
    edited May 2015
    Hi Ram,
    I think you are participating in AOC INDIA 2015 contest.
    If you think the results are as expected, please go ahead and submit the results image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
