By using the functionality “Batch Solve” available in the Flux Supervisor. Once your Flux projects (2D, 3D or Skewed) are ready to be solved, you have to follow the steps below:
| 1 | In the Supervisor, select the folder containing the projects to be solved |
| 2 | Select the software 2D, Skew or 3D |
| 3 | Click on Batch solve and select the projects to solve. You can also use the “Select all” button. |
| 4 | Click on Solve several projects button. All the projects will be solved one after another. Note that the batch will try to solve or continue all the existing solving scenarios in each project. |
| 5 | It solves the projects |
