In order to create a sphere in Modeler 3D of Flux, you have to follow the procedure below :
| 1 | Create a geometric parameter RADIUS=1 from menu Construction->Geometric parameter->New
| 2 | Create two reference points P1(0,0,2*RADIUS/3) and P2(0,0,-2*RADIUS/3) from menu Construction->Reference->Reference point->New
| 3 | Create a reference line between P1 and P2 from menu Construction->Reference->Reference line->New
| 4 | Create a sketch in the XZ plane from menu Tools-> Sketch->Create
| 5 | Create an arc with two extremities points
| 6 | Parameterize the points P3(RADIUS, 0, 0) and P4(-RADIUS, 0, 0)
| 7 | Create a segment to close the arc
| 8 | Close the context Sketcher 2D
| 9 | Extrude the face 1 with extrusion type Around axis from menu Tools->Extrusion->New
| 10 | Repeat the object 3 times with angle 90 around axis 1 from menu Tools->Circular repetition->New
| 11 | Assembly the 4 objects from menu Tools->Assembly->New
