When installing postgresql-10.1-3-windows-x64.exe what are the minimum options required to support hwDesktop2021.1_win64.exe
I get the error 'psql: server does not support SSL, but SSL required.'
I'm installing on Windows 10 professional.
regards,
Carlton.
Hey Carlton,
We are sorry to hear you are not able to install postgresql. Below is the requirement::
System Requirements
I do have few queries - Are you installing with Admin account? Please note windows throws error if you run it using your own login (even if you are admin). You need to Run it as Admin as noted in install guide. I'm re-posting the steps from install guide again :
Let us know if this resolves the issue, if not we can debug this further..
Thanks,
Vikas.
Vikas Aher | Program Manager – Model Assembly
Altair | Nasdaq: ALTR
M +1 248.251.6498
vikas.aher@altair.com | altair.com
Connect with us: LinkedIn | Twitter | Facebook
DISCOVER CONTINUOUSLY.ADVANCE INFINITELY. #OnlyForward
