I have created Entry & Exit points for a rivet point in excel and saved in .CSV format.
when I upload this .CSV point for river creation in " Connection > Rivets > Import rivets from .CSV ", I am getting this error
Hello, Nithin.
Do you already have another manually declare rivets in your model? The warning indicates that there's an existing rivet in the same zone where you want to import a new one.
Make sure the existing rivets are not close to each other in a radius of 5-10 mm to each other, try and reduce the rivet diameter before importing the .csv to see if that works.
Some recommendations:
Let me know if this works.
Best,
R.
