You need to understand first of all the hierarchy for HW Desktop scripts. (Check HWDesktop reference guides in help)
Every control is embed in its own level.
Page related commands are tied into the Page Handle.
Window related commands are tied into the Client Handle.
I'm far from the computer, but it would be something like this:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj ; #can't remember if proj comes before sess..maybe needs to change
proj GetPageHandle pag1 1
pag1 SetLayout 2; #need to check the command and code for 2 windows in this page
pag1 GetWindowHandle p1w1 1
p1w1 SetClientType 'pre'; #dont remember the exact command but it should be inside the page handle and need to check if it is 'pre' for HM or 'model'
pag1 GetWindowHandle p1w2 2
p1w2 SetClientType 'post'
hwi CloseStack
Maybe these are not the exact commands, but it is almost like this.
Thank you Adriano
