I actually encounter problem for meshing two tubes forming a T shape with two shell tubes (which will have different thickness and so belong to two different components), the pictures below describes the general idea:
However the mesh (created using 2D Automesh) for the blue tube and the red tube don't match:
My question is how can I make them match without using equivalence because it creates bad quality mesh and result in failing the simulation?
Thank you very much for your help
