Hi,Can anybody help me with the attached error message.
Hi abpatil,
You need to ensure the HXJM (job manager) is configured in the hx configuration settings.
Click on the plate meshing wizard button to display the HX Configurations Settings window. Click on use HX job manager, click the Next button to configure the path for HXJM.
In HX Job Manager EXE Path – Select the path where HX Job Manager is installed. You should select the folder where the HX Job Manager binary is located.
You can then launch the HXJM.
If you do not have the HXJM installed, this is a separate tool and is not part of the default package.Please contact your professor and get in touch with the Altair account manager for your University and ask for this tool.
This is needed only if you would like to use the HX Job Manager to manage your HyperXtrude runs.
