FAQ8. How to change one or more dimensions of existing geometry
1. Click Geometry > Edit > Surfaces > Dimensioning to open the Dimensioning panel.2. Click the point in the model for point1.3. Click the point in the model for point2.A dimension manipulator with a value is created between the points, which represents the thickness of the part.4. Click the dimension text for the dimension manipulator created in the previous step.5. Enter the new value and press enter.
