FAQ16. What to do when you are unable to specify a min elem size lesser than a particular value in automesh panel?
In the menu, go to 'Preferences' --> 'Meshing options' panel, or press the <o> key.Specify the element size in the element size field, this specifies a default edge length for elements, in the same units that the loaded model was created in (mm, inches, etc). This determines the default values whenever meshing, such as in the Automesh panel.
